Alden_Sloe
So, I'm very new to recording. I'm not a musician but I'm having fun helping my son record some of his work. He sings and plays piano. Those I've been able to record with mics. I've also recorded acoustic guitar from mics. Now he's got an electric guitar and an amp which only serves to further reinforce the feeling that the more I learn the more I begin to understand how little I know
He bought a cheap amp. A Brand X which is a badge Fender puts on a line they have made in China. I know you tend to get what you pay for but since this is supposed to be a learning experience for $40 on Craigslist I figured it would be worth it for experience if nothing else. I'm of the opinion that if your first car is a beater you'll end up knowing a lot more and have a much better appreciation of a fine automobile later on in life
Back to the amp. The first experience was that of problems with excessive noise. I think the proper term is hum as buzz seems to refer to resonances from the guitar. But I started doing some experiments and it seems the hum isn't there when nothing is plugged into the input. Plug in a standard instrument cable and buzz. Mmm, the cable seems to be acting like an antenna It's not a balanced cable and I'm not sure what shielding a "standard" instrument cable should have. I tried two mid priced different brand of cable and same thing. I didn't have a balanced (TRS ?) cable to try but I did have a set of stereo headphones. I know, you're saying what?? this fool plugged a set of headphones into the input of a guitar amp Well, yes I did. Guess what? No hum. And if you turn the volume way up you start to get feedback; nice "clean" feedback with no hum.
Next experiment was to plug in a microphone cable. 1/4" unbalanced jack on one end and XLR at the other. Without a mic same hum as the instrument cable. But connect a cheap dynamic mic and no hum with the mic in either the ON or OFF switch position. With the mic on the sound out the amp is pretty good. In fact clean is very clean and seems better than through the preamps of either my Roland MMP-2 or Fostex MR16HD! So I think we've at least got a decent little amp
If you're reading this saga so far you're likely wondering, "What about plugging a Guitar into the Guitar amp?". Well, we did try that. Hum, buzz, just about all manner of bad noise. How good is the guitar? Well, refer to the comment above about owning your first car It's an old Harmony solid body (not vintage, just old like me ). Hey I'm sure we'll get our $20 worth of experience out of this investment. Like did you know there's a fundamental difference in the way humbucker and single coil pickups are wired Here's another thing I discovered, if I touch my finger to the metal of the 1/4" jack on the guitar the noise almost dissappears. The nut which secures it to the guitar was a little loose and I've only finger tightened it at this point but I think there's a grounding issue at work here I also noticed that there's some play in the volume knob (pot, see I'm learning) which may improve with cleaning or simply need to be replaced. The great thing about a $20 guitar is I'm not afraid to open it up and experiment.
So, any tips, tricks or advise on where to go from here in minimizing the noise would be greatly appreciated. Failing that I guess there's always the Lynard Skynard approach.... "turn it up"
