New Track - Kinda weird Orchestral Prog
Dave52
Hi guys,
Really getting into my Home Recording. Here's a track I've just finished. I found some free to use footage from the early 70s, worked pretty well I thought.
Let me know what you think.
YouTube
Cheers,
gecko zzed
Grumpy Mod
The percussion and bass gave my headphones a bit of a workout, but nice work. Something interesting and different.
Dave52
Thanks for having a listen! Was the bass too much? Sounds good on my monitors but, I think they have a tendency to make me mix with more bass than I should.
Cheers,
jm67
I like it - it's got a little Genesis and van der Graf Generator influence thrown in, but also very contemporary.
Maybe the synth and bass are a little "buzzy" .
There's something about the vocals that could use work but I can't really figure out what should change. They're pretty dry - maybe messing with an effect and using that to build some stereo width in the vocal would be interesting.
Dave52
Hi, thanks for listening... I'll take the Genesis reference :)
I was thinking a little more reverb on the vocals. I'm always worried about over doing it - so I probably didn't put enough on.
Bulls Hit
Nice track. The piano sits well. I like that change up at 2.30. On headphones here there's nothing that sticks out needing attention. Good job
FairWarning
Maybe try raising the vocal level to sit slightly out front of the instruments and use the Dolby Type A trick on the vocals to add that extra something.
Dave52
Thanks FairWarning - I'm not sure what the Dolby Type A trick is...
Manslick - Is that a good thing or a bad thing?
Thanks for having a listen guys!
FairWarning
Described in detail here.
Good overview in this video. Vocals are covered at 1:20.
Once you hear it you'll recognize it and it then it will likely wind up as a standard addition to your vocal chain :p
