badassmak
Herbi-Whore
I have recently installed a new Delta 66 on my machine, alongside a SB16 (it only took like 5 days to install). Uh, I'm finding the vast amount of options overwhelming at this stage.
What I would like to be able to do, and what I think is the right angle, is to use the SB for mere playback and monitoring purposes only. Utilizing the Delta to record only. (If I had some nice nearfield monitors, Im guessing then Im better off using the Delta, for playback and monitoring)
What I'm doing right now is running a right and left unbalanced line from my mixer into the 1 & 2 inputs of the Delta. This is stereo I believe, please correct me if I'm wrong. (It looks right cause both the Delta and my Behringer mixers are showing a right and left.)
Now from there I've got 2 unbalanced lines from output 1 & 2 of the Delta, spliced with adapters into the line in of the SB. The reason I did this was because n-track doesn't want to let me use the two cards together (ASIO and MME). But then I found the other options for the Delta, in File>Preferences>Wave Devices. So I changed the settings too Inputs ; 1/2 MME Delta...Outputs SB PCI MME. It lets me do that, but the sound comes out all farty and slow as hell.
So far with this setup, and a few others I have tried I still seem to only be able to get sound out of my left speaker. I have moved the pan sliders on the Delta control panel, and it seems to look right in the Delta mixer. ie the signal in the mixer reacts to me slidin sliders....
Maybe Im overlooking the obvious?!?!?! (I bet I am)
I know that eventually with enough time well wasted I can figure this out for myself, but I dont want to trial and error this simple thing till next XMAS too!...Any ideas or ways to help setup my setup for optimal use would be much appreciated ...
PS Im leaving for holidays on Friday, itd be nice to lay down 1 nice tune in the day before that happens
