Stark444
i want to set up some recording equipment, and im having difficulty deciding the next step. i bought the book that a lot of people on these forums suggest, "home recording for musicians for dummies." ive recorded a little in the past on a tascam us-144 http://www.tascam.com/products/us-144.html and id liked to stick with something similar since it allows you to make changes a little easier later on. so, i bought a new puter http://www.tigerdirect.com/applications/searchtools/item-Details.asp?EdpNo=5013689&sku=B69-0118 and im going to double the ram and get a secondary HD. id also like to upgrade from the 144 to something with more channels so i can record a drum set in a broader way. i was looking at 8 channels. this leaves me with this idea: http://www.tascam.com/products/us-1641.html ...this comes with cubase, which i have used before, but id like to make the switch to pro tools. im not sure if the 1641 is compatible with pro tools, because when i check out their site, it looks to me like you have to buy their interfaces. is this true? sorry if this should be posted in the pro tools section, but i also thought it was a bit newbish. if it is true, and i have to buy their hardware with their software, then im not sure where to go from here. it would seem that it would cost me more as well. i tried looking around on their site, but the only thing i could find that would fit my wants/needs is this http://www.digidesign.com/index.cfm?langid=51&navid=464 which is a bit pricey. is their another option? what do u guys recommend? keep in mind that i chose the switch to pro tools because it seems to be the standard meaning i will get more help. and keep in mind that id like 8 channels to record a drum kit close to its entirety.
thanks in advance!
thanks in advance!
