R
rockironwebb
senior newbie caveman
Hello me again, supernewb. OK, Alesis multi mix 16 firewire, 7 drum mics, acid pro 7, mixcraft 5. Pc is beyond required specs of software.
Two issues.
1. with mixcraft, I can record all seven seperate tracks with no problems and good sound for the most part. The problem is when I hit play using the alesis mixer as my playback device, it usually doesn't work, sometimes, but usually not. I have to go in and switch over to wave for playback, and yes I have the aslesis set as playback device.
2. When using acid pro 7, I can record all seven tracks just fine, again sounding ok. In acid when I hit play, There is absolutely no issue with playback through the alesis mixer., my acid problem is intermitent audio cut out while recording.
Any thoughts for a caveman drummer? Like I said, PC is beyond specs, defragged, and not really used for anything but recording and e-net
Please help!!
Two issues.
Please help!!
