Steenamaroo
I think I get what you're asking, but just to be sure..
You want to be able to record new audio, but at the same time be able to hear existing audio, like a backing track or drums?
If the above is correct then yes, you can do that. Any daw will let you do that. It's the principle of multitrack or 'sound on sound' recording.
As far as using your monitors as you 'main mac speakers', that's no problem either.
In audio/midi setup in utilities, you are given options to select devices for
System sound playback
Audio playback
Audio input.
If you select your interface for audio playback, then itunes etc will play through your interface, and through your monitors.
You can usually choose which specific outputs are used, so if you want, you can even send itunes etc to headphones.
Of course, you still have the option of just using your built in speakers for 'day to day' playback.
I think you're good to go.
Audio playback
Audio input.
