R
rogiblasko
Hi, I'm lucky that I came across this forum since I almost bought $300 worth of foam to cover every single inch of my room including the ceiling. I thought I'd just cover it all up and call it fixed.
Anyways, I have a new room where I'm setting up the studio and I this time around I need to pay some attention to the acoustics. I will be using it to mix and record, however, all of the recording except for Vocals will be digital. Aafter 20 min of research here - it turns our my problems will be the low frequencies and not really mids and highs. It says that I should treat the corners with the foam to take care of the low frequencies and I also found out that Owens Corning 703 Rigid Fiberglass Board from Home Depot would be the best solution for an over all insulation of the room. The rest of the info is mostly fresh and scattered around my brain because it's 6am on Sunday Morning and I couldn't sleep.
Room dimensions:
width, length, height
125 x 118 x 96 (inches)
10.5 x 10 x 8 (roughly in feet)
I'd like to cover all four walls and the ceiling.
2(walls) x 84(sqaure ft) = 168 square feet
2(walls) x 78.5(sqaure ft) = 157 square feet
Total of 325 for the 4 walls
Windows will be boarded and there are two doors that I don't mind covering up.
Ceiling: 105 square ft.
I'm guessing the first step would be to get the foam for the corners to avoid the issues with the bass frequencies.
The 2nd step would be to get owens corning 703 rigid fiberglass at home depot [http://www.homedepot.com/webapp/wcs...lass&langId=-1&storeId=10051&catalogId=10053], but options are many(tickness, sizes) and it looks like its the kind of foam i'd have to put sheetrock over. Is there another solution?
I'm also looking at http://thefoamfactory.com/acousticfoam/wedgefoam.html
Is there a better or cheaper place where I could get more for my money and how much area should I cover for the best results?
Please be specific with your answers, i'm not familiar with room treatment. The more specific you are the less room I have to do this wrong.
Rogi
Room dimensions:
Rogi
