new boy in town
  • Thread starter Thread starter bolidin
B
bolidin
hi everyone
i just got a roland vs890 and ... wel if anybody would pass some of them tips i will really apreciatethanks
javi
You will likely find you will get more responses to very specific questions than a question that is overly general. Also, there is a Roland thread on this site, that may be helpful to you.
vs890
Oh I'm bored. Here goes.
Oh advice, I'm "full of it". This advice applies to any new peice of gear.
The primary advice is :
USE IT! It's a tool. Just like guitars and amps. Don't get caught in GAS (Gear Acquisition Syndrome) Be a musician or an amateur recording dude .. don't just be a dude with a vs890. Ask yourself if you have GAS.
But here's some actual good advice:
- Have fun. Respect your equipment and you'll approach music more professionally.
- When at your vs890, pretend that it costs you money to be there. That will force you to be professional about it, which leads to more productivity.
- Don't use a gadget (on the vs890) simply because you have it. That's like going through the presets on a Casio keyboard at the local electronics store. Annoying and un-productive.
- You can't fix a bad take. It takes much less effort for the musician to simply do it over!!! So tell the guitarist that it's too damn bad and that he should re-record his so-called "almost perfect" chorus.
- Get a tuner. Force people to use it.
- Don't let dust/heat/crackers get into the faders. Cover the device when it's not in use. Scratchy faders leads to disrespecting the gear. Look it's not a million dollar peice of equipment, but it's yours. You've earned the right to use it for years and years because YOU toiled to save the money and YOU have a vision.
- Don't use it's onboard FX on your mixes unless it's just for messin around and demo'ing it's capabilities.
- Don't ADD EQ. Only remove EQ. Solve your EQ problems by positioning your mics properly , not by goofing around with compressors and eq's. (Recording engineers use EQ's to make well recorded instruments sit in the mix better, so don't touch the EQ until later.)
- Use good cables.
- Use good microphones in good rooms.
- power cables and audio cables should cross at a 90 degree angle to avoid hum.
Tristan
thanks a lot. i was just introducing myself
javi
thanks a lot
no use for the internal effects, i got it
javi
E
Replies
7
Views
1K
DrewPeterson7
DrewPeterson7
rax2112
Replies
9
Views
332
E
TulipAcid
Replies
6
Views
1K
scottmartin
