dachay2tnr
One Hit Wonder
Chris Long said:EDIT: I just uninstalled the .42 drivers and installed the .27 set. With the buffer setting at 512 samples, everything was the same. But when I edged it up to 1536 samples, the popping and clicking FINALLY seemed to go away. I have a latency of 34 msecs at that setting (44.1). Might try the .36 driver set (only one I haven't tried yet) and see what happens there.
34 ms is fairly high latency. However, if you are not using Input Monitoring or recording "live" midi, it shouldn't have any impact on your work.
Good luck.
Oh, and btw, there is a newer set of drivers than the .42's. M-Audio has a .46 driver available which you can get here: http://www.m-audio.com/index.php?do=support.drivers&ID=
filename is: Delta_1007_web.exe
