ido1957
9K Gold Member
http://www.lightningmp3.com/live/file.php?id=20460 - rest of the mix
http://www.lightningmp3.com/live/file.php?id=20461 - bass line
http://www.lightningmp3.com/live/file.php?id=20462 - my mix so far
Would greatly appreciate some bass mixing advice. I'm trying to get that classic punchy tight bass line which sits in the mix without being boomy.
When I mix this with bottom end so I can hear the bass it's all boomy and clouds up the mix. When I reduce the bottom end and up the mids it doesn't get defined, it just disappears.
I have a couple seconds of the raw tracks (bass/rest) which are 320MP3. I also have my bass cut/mid boost mix as as sample. It's also 320MP3. I'm hoping a few of you HR guys will try mixing the bass in and let me know what eq settings you used so I can try and copy them. And post a link to your mix so I can compare.
I've spent a lotta hours on this and am getting not great results so I'm hoping for some help here. I normally would play around with this but I'm honestly getting frustrated and could use some advice.
Appreciate any advice you guys can provide.
