NL5
Unpossible!
Anybody know where to get info on this mic?
Thanks,
NL5
Thanks,
NL5
NL5 said:Harvey,
Do you know what the difference between the 92S and the 92.1S is?
I looked all over the Gefell site to no avail...
Thanks.
sdelsolray said:It's basically the same mic. The 92.1 is updated, lower noise and a few other tweaks. Fletcher should know, as Harvey mentioned. So should Tom at Tidepool Audio.
Dot said:The difference between the Gefell 92S and the 92.1S is.... the 92S had a heater voltage adjustment inside the microphone. It was made for running cable lengths of longer than 50 meters. Gefell wound up not being satisfied with having it in the body of the mic. With the 92.1S the heater voltage adjustment was moved and is housed in the power supply. That's the only difference between the two models.
If you're looking at getting a 92S for the studio and will just be doing normal length cable runs, you won't even have to worry about it.
