Need help setting up mixer!
  • Thread starter Thread starter Steve Kenny
Steve Kenny
Hope I'm posting in the right place!
I'm trying to setup a behringer xenyx 802 mixer. I have a kaoss pad 3 plugged into the send/return along with a mic and headphones. Then I have outputs on the mixer going into a m-track 2x2m interface. Everything works fine until I record something in mobius looper,I can only hear the loop if I plug the headphones into the m-track. Is there a way I can route the sound into the mixer to hear it being played back? If I have the headphones plugged into the m-track instead,the sound coming from the kp3 has a second delay.
Cheers
You should be able to do it this way.
Connect the output of the interface into the 2-track inputs on the mixer.
Press the 2-trk to ctrl room button.
You can monitor the kaos through the control room outputs while it is going to the interface via main mix, and you can hear what's being played back in the computer. The mixer's headphone socket looks like its permanently connected to control room.
Don't post in multiple sub-forums. Just post one thread per topic. A mod will move it if it's in the wrong place. This forum is busy enough that you'll get lots of response no matter what category you post in.
