K
kratos
to finish the title - and drums aswell...
Heres a sample of the work done so far its not in the exact order as i brought in all the instruments at once...This song is actually for my upcoming album but if i dont mix this song properly tis will be a shame
http://soundcloud.com/user245745
Heres what I did to the instruments + female singer:
Piano: Concert reverb plate used
Eqed:
rolled off 250Hz
cut 395Hz by 5dB
cut 921Hz by 10dB
Female singer:
Eqed:
Rolled off 120 Hz
Compression used on her:
Ratio 3:1
48.9 ms attack and 174 ms release
Reverb:
decay: 2.0ms
room size: 50/100
Reverb %: 10%
Colour: Bright
Predelay: None
LowCut: 389Hz
Highcut: 4.0kHz
High Damping: 5.4kHz
Dry: 100%
Diffusion: 100%
Delay: Time 4:00
Strings:
Eqed:
rolled off 200Hz
cut 1480Hz by 5dB
Raised 12000Hz by 10dB
reverb: Concert reverb plate same as the piano
Strings 2:
Same settings
Hihat: none
Snare: Slight Reverb
Kick: Just raised the eq
Synth:
Eqed:
Rolled off: 100Hz
Cut 1400Hz by 4dB
Raised 7300 by 6dB
Reverb:
decay: 1.5sec
Reverb %: 20%
Roomsize: 40/100
Colour: Flat
Lowcut: 75Hz
Highcut: 4.0Khz
High Damping: 4.0kHz
Dry: 100%
diffusion: 100%
Brass stereo:
Eqed:
Rolled off 50Hz
Cut 310Hz by 3dB
cut 1890Hz by 5dB
Reverb: same plate as piano and strings
Brass mono played one octave lower on top of brass stereo:
eqed:
roilled of 50Hz
Cut 445Hz by 10dB
Cut 2300Hz by 10dB
reverb used the same reverb plate but reduced the reverb effect by 80% since its a bit bassy
Bass used is a sub bass: nothing done
Piano, brass and string samples are in full stereo by the way
can someone please tell me if there are any rules in eqing and panning:
1) Strings
2) Piano
3) Brass
4) Synth
Or possibly suggest me some songs which may have the same instruments so I can learn from that and stuff...
So far I think I got the beat and the strings to fit together and I think I got the female singer to sit but I'm not sure what type of reverb to use...
Its just the brass and piano which keeps bugging me...
Eqed:
rolled off 250Hz
cut 395Hz by 5dB
cut 921Hz by 10dB
Female singer:
Eqed:
Rolled off 120 Hz
Ratio 3:1
Reverb:
decay: 2.0ms
room size: 50/100
Reverb %: 10%
Colour: Bright
Predelay: None
LowCut: 389Hz
Highcut: 4.0kHz
Dry: 100%
Diffusion: 100%
Delay: Time 4:00
Strings:
Eqed:
rolled off 200Hz
cut 1480Hz by 5dB
Strings 2:
Same settings
Hihat: none
Synth:
Eqed:
Rolled off: 100Hz
Cut 1400Hz by 4dB
Raised 7300 by 6dB
Reverb:
decay: 1.5sec
Reverb %: 20%
Roomsize: 40/100
Colour: Flat
Lowcut: 75Hz
Highcut: 4.0Khz
Dry: 100%
diffusion: 100%
Brass stereo:
Eqed:
Rolled off 50Hz
Cut 310Hz by 3dB
cut 1890Hz by 5dB
eqed:
roilled of 50Hz
Cut 445Hz by 10dB
Cut 2300Hz by 10dB
1) Strings
2) Piano
3) Brass
4) Synth
