A
astyle
I was thinking about something... If you connect all your synths to channels on a mixer, then what will you record? The stereo output of the mixer with all signals combined? Maybe a patchbay would be a better choice than a mixer. You can rack all your synths (assuming they're rack mountable), then connect the outputs to the backside of a patchbay. You could route the input cables from your interface to the patchbay too. Then just patch the out from the synth you want into the interface input of the channel you want. Ideally, I'd think you'd want each synth track recorded separately.
Jeff you really are helping me out here. I appreciate you making sure i get the right stuff, not the cool stuff. I feel like that is a reoccurring theme when it comes to audio.
I looked at some patchbay's. I am a little confused as to what they are for. Looks like line in line out, dont know what kinda magic happens in between.
The reason i thought i need a mixer, is because currently all of my production is done in ableton. I bring up 10 or 12 synths or machines and like to adjust volumes, velocity's, and frequencies after adjusting their sound and creating the pattern.
I feel like it should be the same with outboard gear. Ill create patterns and tones in patterns on each synth. Then when im ready to record, i can bring them in with the faders or switches. I dont want each synth to be at the same volume. In this post production i also like to adjust the frequencies, maybe there is too much bass on the moog, so ill hit up the 4 band eq and adjust accordingly.
With the line mixer's you dont have the option of adjusting highs mids lows.(from what i first looked at).
Am i on the right track with my thoughts?
By the way. The allen & heath i think is what i am looking for. Not only does it sound and look really good, but it has a USB interface which works perfect for me since i use a pc with ableton/ cubase for adding missing instruments/effects
