D
deville2010
Basically i'm just recording a lot of tracks in my 6x3 size closet with acoustic foam (that i'm working on)....but i want to be able to shop my demos and rough drafts without the overall "pumping" sound i get wen i mix myself.I kno it best to pay for mixing and mastering but i dont have the money for that type of process right now....
First off i'm putting a effects chain on the vocals which consists of:
these fl studio effects:
...Parametric EQ with 12105Hz @ 31%, 365Hz @ 20%, and 52 @ 76%??????watever that is......
a Soft type compressor with 0 threshold, 3:0:1 ratio, 9.0 gain, 18.1 attack, 180 release...again??? i sorta understand compression but not really!
a high pass filter with a 5.8 gain, 79 freq.,
a desser effect
and maybe a little reeverb........I don't kno i just try to make it sound good thru my headphones, and stereo speakers
I use a AKG Perception 220 with a M - Audio Box..
Do i really need a vacuum tube box or some other type of compression tools to make the vocals compressed from the get go or what???? What Ratios should I use... does it matter about compressing the vocals from the start???
Am I doing way too much or not enough I need help because Columbia College in Chicago is Expensive!!!!!Lmao
a desser effect
