Need Diode recommendation on cheap, defective Epiphone Distortion Pedal
chrisghost
I bought a defective Epiphone distortion pedal for cheap.
It was easy to determin the problem; a big piece of the ceramics on the diode was chipped off.
This is a 10 cent fix, the only problem being that the value of the diode was on the missing piece of ceramic, so I don't know what to replace it with.
Any thoughts/advise?
chrisghost
Maybe an 1N4148.
Thanks, but no, I found a picture of the print. What I could read is that it was something ending with 07, so it could be N4007, but I could be a 0 off. Better not risk it. I'll do some more research tomorrow.
ranjam
If it's part of the power supply, it is likely a 1N4007, and very much overkill. Those are rated for 1,000VDC and 1A; not likely to be seen in your pedal. Those are usually in parallel with the internal power supply in such a way that if a reverse polarity external power supply is 'accidentally' plugged in it will just be shunted through to ground. Hmm, maybe an overkill diode is needed.
