EIK said:
I'm thinking about picking up the $190 Sansamp bass driver DI. Do I really need this though to record my bass that has active pickups? I have a hartke 200watt combo with a 15" speaker.
Some mics I could use: akg C3000B (would be kind of a hassle since I use this for vox. and ac. guitars), SM57 (won't realy pick up all the frequencies i want). I could also go straight to a VLZ Pro Mackie mixer as well.
Any suggestions?
Thanks
What do you use as preamp for vocals? Can't you run thru that, just turning phantom power off?
Of course, that won't help you color the sound, which you may want to do. Neither mic you mention is ideal for picking up bass. For simple home recording I've found that going direct really is the best method, as it's the simplest and easiest way for me to get a decent sound. And my active pickups on my bass don't output enough signal to do away with some preamp boost. So ...
Instead of getting a Sansamp, you could consider a cheap preamp ... some rave about the ART Tube pre (what, like $99?), but if you ask me, the cheapo PreSonus BlueTube sounds better (for $149). And yes, I've tried them both. Both let you dial in tube flavor ... in this eschelon of pres I'd euphemistically say it's tube "grit." But it does warm it up and fatten it up some.
Actually, there are so many low-cost pres out there worth considering as a DI ... then you'd have a decent pre for other uses to boot. I'd think you'd want a "color" pre, either something with tube or with a distinct flava. I now use a racked Neve as bass DI, and in my limited setup, that's definitely my preference. It's certainly a preference over going into the more neutral pres I have as inputs going into my soundcard.
I think most pres accommodate DI use ... every one that I've used, in my limited experience, has ...
Well, I hope this is useful.
