I
ifpo238
My setup: Sonar XL, Aardvark Q10, Roland XP-30.
Questions:
1. When I choose inputs and outputs for an audio track in Sonar, I have to choose pairs of inputs or outputs, rather than single inputs and outputs. Is Sonar not capable of addressing all of the Q10's inputs and outputs individually? Is this a shortcoming of the Beta driver I'm using? I'd like to keep inputs 1-4 for mics, plug my XP-30's left channel into input 5 and right channel into input 6, and use 7 and 8 for bass and guitar. Ideally, I'd be able to keep the stereo separation from the XP30 when I record audio from it. Right now, when I arm an audio track and select input 5/6, I get audio recorded that appears to me to be a mono track, panned center. Both speakers playing exactly the same thing. Boring!
2. When I try to use any audio effects on the audio I record, I get an error message that the effect doesn't support that bit rate/resolution or something like that. I checked, and I'm set up to record 44.1 at 24 bit. Do I need to change these settings? Will the effects only work on 16-bit audio? Or is this a problem w/ Aardvark's driver?
3. I'm using the XP-30 instrument definition that came with Sonar. Blech! Is there a better one out there? I'd ideally like to see patch mode definitions that group all the similar sounds together like the "category" mode on the synth itself does. I don't want to have to hunt for my "big hair lead guitar." I want it to be right next to my "distorted electric guitar 2" or whatever.
4. Has anybody played w/ the ReValver SE amp simulator? How does it sound? The only working electric guitar in my studio right now is an Epiphone LP Xtreme. I have the option of recording through a Peavey practice amp into an SM-57 or direct into the Q10 with amp simulation in ReValver. Any thoughts?
I know I have lots of questions. Thanks for your patience!
-j
Questions:
-j
