R
RFsoundguy said:dither down to 16bit/44.1kHz
RFsoundguy said:When I plug an unbalanced source into them, my signal into the board is about -6db down and I have to crank the fader WAY up, crank the input gain on the board WAY up, to get it to level out. ...
with the balanced kit/option and connection you will get as much 'cleaner signal' (comparatively to the signal you get with unbalanced connection) as much the connecting cable you are using is 'capable' of adding (picking up) the "dirt" (noise that is). A short unbalanced cable (6-10 feet) isn't capable of adding much dirt that can not be ignored.RFsoundguy said:I like clean signals, which is why I want a balance output on the 112mkII.
If you can't find the balancing kit there are other options to convert unbalanced to balanced - if you're handy with electronics you can do it with two op-amps, I have just pulled two domestic Teac decks out of a transmitter site today and one of them had been modified this way. (the other has a burned out capstan motor on deck I but that's another story) There are also interfaces available, both vintage Tascam and newer stuff from other suppliers, which can do this.RFsoundguy said:Well, the balanced I/O option would allow easier level matching on my fw-1884. +4db outputs to +4 db inputs. Raises the signal above the noisefloor, better S/N ratio, etc. You know this stuff.
For cassette conversion to CD I'd sample at 24/44.1 or 16/44.1 - the former gives you headroom to screw up your levels a bit (!) and the latter saves any kind of dithering. Both of these options mean you're not having to do sample rate conversion, so cutting out one extra layer of digital manipulation.RFsoundguy said:Is it really necessary to convert the analog audio to 24bit/192kHz digital audio then dither down to 16bit/44.1kHz (the CD standard) or would the 24bit/96kHz converters built into my board be sufficient.
Tim Gillett said:It just occured to me I dont remember RF soundguy saying what or if NR was used on all these tapes. It could be dbx.
Yes.RFsoundguy said:... do I just switch in/switch out the different shcemes until it sounds best? .
heh heh heh!CBS Records on SADE (Promis) cassette-album said:This tape is mastered to Dolby "B" standards for noise reduction. Decrease treble response when playing on non-Dolbyized equipment.
Beck said:Back in my young cruising days that little Dolby B button was a great high-end booster in the out position...![]()
Tim Gillett said:I think those who just dont like it have not heard it as it should, or if they have, dont know when they're hearing it.
