Re: Know what you do not know....
Originally posted by sonusman:
If you are going to share what you don't know, but put it across like it is something you do know, then have the balls to argue what you don't know with people who DO know it, then be prepared to be corrected, and in sometime harsh and somewhat rude ways.
I have no problem in being corrected. When I'm not very sure of what I say, I only answer if nobody else have given an answer, and I point out that I'm not sure. If you look at my posts here you will find some of those.
Sometimes I may leave out a bit of technical detail that I find only will make matters more confusing, and I do often leave out the obvious. Then you come picking on me, claiming I am wrong, when I'm not, and in the process giving out bad advice. THAT'S what I have a problem with.
As an example of obvious detail I have left out is that yes, one microphone put to good use may sound better that four mics put to BAD use when recording a drum. Thats obvious, Ed, and I didn't feel the need to write that. But you come pouncing on this, straight away! Why? What was your point with that, unless you were looking for some kind of way to claim that I was wrong?
As to the equipment that you have used that will not allow you to reach digital full scale while recording
Excuse me? I have NEVER claimed I have used any such equipment.
I can guarantee you that it is possible to reach 0dB on those meters while recording and not have clipping.
Sure. This is not the issue here. The issue is if you KNOW if you are just exactly touching full scale or if you are clipping. You yourself write "The converter has no way of knowing that anything above that voltage value is in fact more voltage or not". I must be unclear in the extreme, or you just simply do not want to understand what I'm saying, even when I'm repeating what you are saying...
