kristian
my latest project... speaker stands
so ive made a plethora of all sorts of cables and learned to solder like a crazy spastic. and ive showed you what me and my brothers do in the summer(not quite music related), and now this is my new plan. my 20/20bas are to akward on my desk area, and hard to position. so ive decided to made two stands out of wood. This was my original idea.
then i realised that most likely it will be really hard to make a central pillar flat enough to be super stable. so i came up with this idea.
this is what i would use as a column instead, i remembered how strong triangles were, so im making an X-like shape with a main piece parrallel to one side and perpendicular to the other. the i will use two same length pieces of wood, only half the widthat 45 degree angles to the other wider piece. With the base from before.
However new developements from my brother's engineering head is that its gotta probblay have a thicker base (which i dont like because it will look ugly. but then i will be able to put balasts in the bas and remove them if we want to reposition. of course each speaker is 30Lbs, need to have somethign of equal weight at the opposite side.
Ill keep you posted on that developement and how sturdy/purdy they turn out.
