Low noise, high output, Proprietary FET design
Large Capsule, Gold Sputtered Diaphragm
Wide, 20Hz-20kHz frequency range
10dB switchable attenuation
Internally wired with Mogami cable
10 dB low frequency cut switch
Weight, 2 lbs. Length 9" "vintage cosmetics"
Comes with hi-isolation shockmount and Deluxe silver carrying case
The MXL 992 has a large diaphragm Gold capsule combining the best of large diaphragm performance and the latest in transformer-less FET circuitry. The 992 delivers the dynamic range required in the most demanding applications. It has an airy open sound with low self-noise essential for accurate, digital recording. With a 20Hz-20kHz frequency range; 10dB switchable attenuation; selectable -10dB low-frequency roll-off; and large brass enclosure; the MXL 992 is one of the most versatile microphones available. Includes Deluxe carrying case and shock-mount.
Type: Six micron condenser pressure gradient gold capsule
Frequency Range: 20-20 KHz
Polar Pattern: Cardioid
Sensitivity: 15mV/Pa
Output Impedance: 200W
Max SPL: 130 dB , 140 dB w/-10dB cut
S/N Ratio: 80dB (Ref. 1 PA, A weighted)
Equivalent Noise Level: 10dB (A weighted IEC 268-4)
High Pass Filter: 6dB/octave, 80Hz. (switchable)
Preattenuation Switch: 0/-10dB
Weight: 2 lbs
Metal Finish: Champagne
Power Requirements: 48V phantom power (+- 4V)
The specs seem to back up the idea that the 992 is a quiet microphone.27mm (1.06”) Large Capsule Condenser
Gold-sputtered, 3 micron density diaphragm
Balanced transformless output
3 position switch: bass cut, -10dB pad
Durable brass enclosure
MXL-57 high isolation shock mount included
The MXL 2003 is intended for the most critical recording applications, such as acoustic guitar, where tremendous clarity, presence, and detail is required. A three position switch provides Bass cut and a -10dB pad for additional recording options. A transformerless FET preamp offers the engineer a smooth, even response. Its 3-micron gold-sputtered diaphragm reveals incredible transparency and warmth, until now, found only in the world's most expensive mics. The MXL2003 comes complete with a high isolation shock mount (MXL-56) that allows precision recording without the interference of outside vibrations.
Type: Condenser pressure gradient mic with large 27mm diaphragm capsule
Frequency Range: 20Hz-23kHz
Bass Cut Switch: 6dB/octave @ 150Hz
Sensitivity: 16mV/Pa
Impedance: 150W
S/N Ratio: 77dB (Ref. 1Pa A-weighted)
Equivalent Noise Level: 18dB(A weighted IEC 268-4)
Max SPL for 0.5% THD: 130dB
Max SPL with -10dB cut: 140dB
Power Requirements: Phantom Power 48V ±5V
Current Consumption: <2.5mA
Size: 55mm × 195mm
Weight: 530g
Metal Finish: Black
