acbar69_2000
Upgrade
Where did you get the puelso capsule for that price. The best price I could find was like 170. Thanks
Where did you get the cAPSULE FOR $120
From John probably, via time travel.
BTW, the thickness of the gold isn't that big an issue. You have to understand that so long as it conducts and the capacitance is where it should be, its fine.
Sputtering is a means of depositing gold on the mylar or PVC in a method similar to spray painting. It means the gold is put on in a kind of lumpy manner. This can effect transients.
If the diaphragm's gold is vapor deposited (by evaporating the gold in a vacuum chamber) the gold layer is smoother and the result is better sound. Almost always with vapor deposited diaphragms the gold looks translucent or even green.
Cool. But did you use a time travel machine or not?
