I'm using a Peavey 4062 mixer to mix down 6 tracks. I have routed the mix to an outboard effect, and put the return from the effect into its own channel input (7).
Everything is fine so far, but here's my problem: I want to hear only track 7 (the processed mix of channels 1-6), but not the channels that make up the send (1-6).
Muting channels 1-6 or pulling down their faders won't work because that's the signal that comes back to 7 (no send from 1-6=no return to 7). There are no solo buttons for the channels either, and no other buttons that would seem to solve this problem. I consulted the owner's manual with no luck.
If anyone is familiar with the Peavey line of mixers, any help would be most appreciated. Some extra bits of info in case it helps: I'm sending channels 1-6 out as a subgroup, through the "Group Out" buss. They are returning from the FX via channel 7's 1/4" "In" jack and processed like a normal channel signal.
