E
etnoziroh
I hope someone can help...
Here's what I use. I record guitars direct through a V-amp2 into Delta 2496 at 48khz 24 bits into Cakewalk HS2004XL. I only use Parametric EQ and compressor VST/DX. I monitor through Roland DM-10's in S/PDIF mode.
In a nutshell, the only plugs I use are EQ and slight compression. It sounds fine but when I compare my mix to some of the more serious demos by more experienced members in the MP3 clinc and other HR sites, my mixes sound muffled with no presence. I'm using general advice from this forum like subtractive EQ and very conservative use of other FX like reverb and so on.
Is it possible with the equipment I have to get clean and presence filled mixes?
I'm very inexperienced but maybe my limit is equipment too? I'm recording direct so there are no shitty mics to blame. By the way low gain settings improve things but even then all of my recordings have the same low quality sound.
Thanks for reading, hope you can help
, time to change procedures.
