M
man-bot
Member
Quickie for the MS-16 owners out there. When you are calibrating in Repro mode, recording 10 kHz - does the Rec EQ pot provide very little adjustment of signal?
I find it may have 1 to 1.5 db of adjustment using it and it almost behaves like a bias adjustment in that as you turn the pot clockwise towards the end of its travel the signal declines again slightly. (I am not saying in any way this is adjusting bias - just to be clear - only that it behaves oddly). Audibly it appears to have very little effect while monitoring, but maybe my ears aren't as good as yours!
Just want to confirm...
Mike
Mike
