cellardweller
Anyone here use both of these?
I'm wondering which output on the DMP3 matches up to the MR8.
I couldn't find it in the manual, but I'm off for a 10th look...
Enlightenment appreciated.
More questions to follow!
The DMP3 has the both +4 and -10dB.Gidge said:If you use a cable with TRS, it will be at +4 ......
If you use a cable with TS, it will be at -10 ......
which you wanna use depends on what you are going into.....
Which one is appropriate for the MR8???chessrock said:Just be sure to match them up -10 output with -10 input and so on. If you don't know what kind of input you have, then who cares? Just select one at random and if you get noise, or your recording signal is too loud or too soft, then try switching to the other.
