Q
quesne
Member
Hello All:
The attached file is a stereo Zoom H4 recording of one song from a little concert my partner and I did a few days ago. The problem (as I see it) is that the guitar and vocals are quite muddy and far behind in the mix, while the mandolin is better defined and pretty much in front of everything else. This probably has mostly to do with mic placement. I used the built-in H4 mic array, at a 90 degree angle. The recorder was placed about 5 feet away (toward the audience), three feet off the ground and well centered in between us.
I am so accustomed to recording in my home studio with each track independently managed, I am not very adept at dealing with a "fixed" mix. I was hoping that someone could help me get the vocal and guitar a bit more forward in the mix and better clarified. If anyone has a moment to listen and give me some advice, I would greatly appreciate it!
Thank you in advance
P.S. The only post-processing I did in Reaper was to normalize the waveform, and remove noise via the "subtract" mode in the ReaFir plug-in. If the unadulterated audio is needed, I can of course provide it. Thx!
