C
conan
Hi guys, I've been away for a while during my move to sunny Taiwan. Miss me? *shakes fists* MISS ME??
Anyhow, you might remember that with the help of you guys I put this together a couple of months back.
I would now like to do something similar.. in a high-rise office block. Yes, bear with me. I happened on a great bargain office in a great area on the 5th floor of a pretty modern commercial high-rise. It seems well built and there is very little noise coming from the concrete outer walls and no traffic noise whatsoever. The office is partitioned into two rooms with a material that seems only slightly more effective at sound isolation than rice paper, but I can deal with this.
Now, get your thinking caps on and help me figure out a way of isolating the smaller partition (about 3 ping / 10 sqm - not a huge job here) with the following caveats:
1) no damage can be done to the existing structure (easy - the whole thing will be floating)
2) minimal traffic through the building's common areas (the disturbance created by 150 8' 2x4s and a few hundredweight of plasterboards in the last project was something else)
3) wood framed structure is a last resort.. technically not allowed, but building regulations mean squat here
So.. any ideas for a way of achieving reasonable isolation other than building a wood frame or pouring in concrete? Some way perhaps of using a lightweight frame then adding mass with the plasterboard? Defining 'reasonable', I was more than happy with the results of floating wood frame construction, single layer plywood floor, 2 layers plasterboard, 100mm fibreglass insulation in a terraced house. Perhaps some thoughts on making prefab panels in an outside workshop then putting the whole thing together in the office?
Cheers guys
Cheers guys
