smoothster
Hello Everyone,
Attached is a small image which will hopefully illustrate this clearly. Basically I have a Monitor + Audio Interface + Balanced Patchbay and need to know which are the correct cables to use.
I am using a XLR --> 1/4" (TRS) going from the monitor(s) to the patchbay (balanced). The Audio Interface will be patched on top (in the back of the bay) and not sure if I should use TS or TRS plugs to connect the AI to the patchbay.
Furthermore, If i was goiung to patch in the front of the patchbay, will I need my normal TS or TRS cables now?
Been doing this forever now, redid the studio, and for some reason
I totally lost all knowledge of tip-ring-sleeve-balanced-unbalanced...Im feeling slightly retarded
Thanks in advance for your help,
smoothster
Equipment is as follows:
Mackie HR824 Monitors
MOTU 2408mk3 Interface
Samson S-Patch + (plus) Balanced 48 Point Patchbay
smoothster
