monitoring with omnistudio (c=
  • Thread starter Thread starter salvetem
salvetem
Hi, i was just wondering if it is possible to use monitors with the omnistudio and avoid using an external power-amp? Im kinda on a budjet so if this is posible it'd be a great help. Muchos bessos (c=
It is possible to use the omni studio with monitors. There are dedicated outputs for them on the breakout box. However, that doesn't necessary stop you from having to use a power amp. It cuts out the need for some kind of mixer, mainly to control volume. It you get active monitors (ones that are powered), you wouldn't need anything else, but to plug them into the omni studio. If you get passive monitors, you would still need a power amp to drive them. The omni studio makes it very convenient to monitor everything you're recording. I've had great success with that soundcard for a couple years now.
Brandon
Thanks brandon. Would you advise the Studiphiles as a good choice with the omnistudio then?
i would've suggested those even if you didn't have the delta card. They seem to be a great bang for the buck monitor. The new SP-8x have since replace the SP-8B and i think don't know if they're out yet, but i would hold out for the 8's rathe than the SP-5B.
Brandon
