N
NYMorningstar
Recording Modus Operandi
I have 2, Fender1275XPs: 15" two-way, 400W peak / 200W program @ 16 ohms monitors. I also have an old Peavey 260H monitor amplifier which says 400 watts and surrounding the speaker outputs it says 130 watts @ 4 ohms. Can I drive the fender monitors with that amp?
. Another thing I'm confused about is whether the 1/4" outputs for the speakers would be considered in series or paralell. I'm guessing it's parallel so would two 16 ohm speakers require an 8 ohm output? Assuming your correct would this be a bad set up and burn up the amp or fry the speakers?
