dgatwood
is out. Leave a message.
You'll notice I've never said anything good about CAD's SDCs. That's because I've used them and they're pretty terrible... or at least I've used the Astatic CTM-1000 that they also build. They seem to be basically identical to the Nady CM-90, but with slightly larger drill holes in the backplate and an added bass roll-off switch.
Anyway, I decided I'd go ahead and remachine the capsule by hand with a Dremel. It took a small eternity, but I ground off the front 1/8th inch of the capsule, resulting in removal of the metal bars that create so much comb filtering. I also rounded off the resulting thin lip at the front and removed one layer of the screen. Wow, what a difference in the sound.
I did have one unfortunate mishap, though. I inadvertently dropped and severely wrinkled one of the three spacers. For now, I'm running it with two, but it seems to occasionally misbehave in a way that makes me believe the diaphragm may be smacking into the backplate. Hopefully the spacer will flatten back out on its own so I can reinstall it.
I'll post samples this weekend if I think about it.
Above: the stock capsule.
Below: the remachined capsule.
