mixing
  • Thread starter Thread starter thomas gaughan
T
thomas gaughan
arial2black
i am new to this site can anyone tell me why it is important not to mix a piece of music at very high levels or low levels of volume
Try for about 85 dB. If your mixes are too loud, they'll sound tame when you turn them down; if you mix too low, they'll be muddy when you turn them up.
hearing limitations by nature
Hey Thomas, how are you?
i ain´t sure if I understand your question right, but pretended you´re asking for the volume you should mix your tracks, I agree with lpdeluxe, 85 dB should be the max, or the natural hearing limitations will affect you to assume the sound different than you think.
Fletcher-Munson is the word here.
check out this link:
http://en.wikipedia.org/wiki/Fletcher-Munson_curves
Hope this helps a bit, if not, email me.
PEACE!
dr.mixphat
www.mixphat.co.nr
thomas gaughan said:
arial2black
you mix at around 85-90db or roughly the amplitude of a blow dryer on medium to high. You get the most even blend at this level (read that flecther-munson note).
However, you can use low and high to your advantage. Occasionally, you can lower your monitor gain to check what instruments are loudest in the mix. You turn up your mix to check that EQing is relatively comfortable and even. However, 90% of the time you want to stay at the 85-90 range for optimum results.
But also, one note that alot of people miss:
Your speakers. Some speakers (and speaker amplifiers) tend to compress naturally by design. So if you don't have a completely clean and dynamic signal coming out of your speakers, and you're not aware of it, your mixes can suffer on other systems as well.
L
Replies
6
Views
1K
Slouching Raymond
Slouching Raymond
T
Replies
9
Views
907
Maya Clars
Maya Clars
W
Replies
6
Views
707
TalismanRich
TalismanRich
J
Replies
9
Views
824
TalismanRich
TalismanRich
