M
Mike Freze
Hi! I have a question concerning mixing vs. mastering.
In all the books I've read, I understand the end process of mixing is to "bounce" all your tracks to a single, stereo file (with the propoer bit and sampling rates, audio formats, etc.). After that, when you import your project (one song) back into your recording software (I use Cubase), it appears as one file on one track. No problem.
Where I get confused is at the end of the mastering process. In some of my books, it says you need to establish the bit rate, sampling rate, audio format, etc. AGAIN. In one book, it says you need to bounce your mastered songs (single, stereo files) again after you treaked your EQs, volume levels, added compression, etc. to complete the mastering process.
How can you bounce mastered songs (files) if they already have been bounced when you finished the mixdown? In other words, all the separate tracks were already bounced once before.
Don't you just re-save your mixed songs with the mastered settings by choosing "save" or "save as" and the changes will be there for the mastered material? If not, then please explain how you can possibly "bounce" songs that were already bounced at the end of the mixing session.
Thanks! Mike Freze
Thanks! Mike Freze
