M
MDodds
is is okay to eq a instrumental around the 10,000/15,000 frequency range by -2 db's to leave a pocket for vocals? jw
P.S I think Miro's post might have been a typo, he probably meant 80hz—11000hz not 1100hz.
Nope...no typo...I was talking about fundamentals not harmonics.
If the OP wants to make room for his vocals, the fundamentals' range is where it will count. Opening up a "hole" in the 10k to 15k Hz area will not help vocals that much.
Audio Frequency Chart
As someone already pointed out...the cello and violin live in the same fundamental (and harmonic) range as vocals...so that's where the problem is. Of course, many other instruments also cover the same basic range...so it's not just a question of cutting away with some EQ.
I say panning, levels and a mix of wet/dry is the key...with a touch of EQ.
...you seemed to be saying this 80hz-1100hz range was the area to cut in the backing...
C an octave above middle 'C' is 880 Hz. If a singer can hit the 'C' an octave above that (fret 15 on the high E string of a guitar) that's 1760Hz, yes there are harmonic frequencies, but not as much in a voice as in a stringed instrument.
No...I said whatever works for the mix....and that the vocal range is around 80-1100 Hz, so cutting around 10k-15k Hz won't do much to make room.
Just for clarity...you wouldn't be touching the vocal anyway in the OP's scenario...you would instead scoop the instruments in the vocal's range to make room for the vocals. What "center point" you use on the instrument's EQ...that's really up to how it sounds.
There's no implication on my part that you would use the dead-center of the entire vocal range as your scoop center for the instruments. IOW...you may not (probably not) ever need to use the entire fundamental range for your scoop range.
You find what works for the mix...the actual range of the scoop may only be a portion of the full vocal range.
