M
M-Bass-M
A lot of the tracks that I have been mixing tend to have both top and bottom snare mic tracks. Currently, the way I have managed my workflow is to just send both tracks to the drum buss, and then applying eq / compression etc to the individual snare tracks.
This feels like a bit of a bind, for example if you want to increase the snare in the overall mix then you have two faders to adjust. I'm thinking that a more sensible approach being to send both tracks to a snare buss, which is then sent to the drum buss. That way I can apply eq, compression etc to a single snare buss, and use the mix of top/bottom to shape the overall sound.
Which method is more generally accepted? Are there pros/cons of either approach that I haven't identified yet?
Cheers
Mark
Cheers
Mark
