C
ClapHands
Has anyone tried it? If you have (and it sounds good), do you know of techniques I can use to make it work?
If you want to compare LDCs to SDCs, you need to be much more specific.
I just recorded some acoustic using an SDC at the sound hole about an inch away coming in from the neck side, and an LCD about 3 inches away. It gave a good sound, but I'd probably try something different next time just because I think I can get a better result. I didn't really have much time to fool around with it unfortunately.
Why do you want a distant mic on an acoustic?
Acoustics don't exactly pump out the volume so I'm not sure what the benefit is, unless you have a really good room and you want some ambience... You may find there's too much noise and not enough signal.
I often use an SDC about the neck join about 9 inches back and an LDC up around the fifth fret about the same distance or a bit closer... but I'm recording big booming dreadnoughts and find the sound near the bridge to be bassy and muffled...
As the Gecko mentioned, you don't want to be too close as you get a highly localised sound, which may not be what you're looking for... can be a bit harsher than you might like...
