I was afraid of making my first post too long...
Ok, here we go then:
I am located in Spain, in the country side. I just bought a house. It's completely detached and there is very little noise around. It's a modern house, built in 2008. The room is in the basement, next to the garage.
Here you can find the original floorplan.
https://img195.imageshack.us/img195/8516/basement1.jpg
And some photos inside the room:
https://img195.imageshack.us/img195/2371/room1wb.jpg
https://img291.imageshack.us/img291/3723/room2i.jpg
https://img401.imageshack.us/img401/4597/room3q.jpg
It's the room on the right of the toilets. The external wall (thicker) is reinforced concrete. The inside walls are 1/2 foot brick. The floor, at present is covered with tiles. There is a cavity that goes underneath the stairs and is about 70cm high. The stairs go across the three stories of the house. Right above the room is the kitchen and the entrance hall. Next to it is the garage and the stairs.
As the room like this is H2.5m x W4.5m x L4.5m (very bad ratio) my idea is to eliminate the toilets and move the access door, like this:
https://img694.imageshack.us/img694/9279/basement2z.jpg
The cavity side would be the front of the room.
I have also thought of taking out the tiles to gain some height. I took one off (more like broke it) and underneath there is tile glue + cement before reaching the reinforced concrete layer. That's about 5-6 cm in height.
Soundproofing targets are basically the other people living in the house. I get to mix quite different material from a classical string quartet to a hardcore band. I would like to avoid disturbing the rest of the house and be able to mix undisturbed. I usually mix at very different levels from very quiet to loud (seldom VERY loud). I use Avantone Mix Cubes, Yamaha HS80s and crappy computer speaker sometimes. I mainly mix using a SmartAV Tango, some plugins, and lots of outboard.
I would like to install Air Conditioning with an external compressor in the near future. The furniture, I have not decided yet. I need to fit a cupboard for my guitars, mics, cables, and all sorts of stuff, but I haven't designed that part yet. After seeing John Sayers designs I'm kinda not knowing where to go (they look really great and must sound even better), so ideas, suggestions and all kind of input is VERY welcome. I hope I have given enough info
