JG96
Active member
Yeah, that's the cure to all sucky sounds![]()
haha i guess from now on my band doesnt have to worry about writing good music just becoming masters of parallel compression.
...He has also stuffed the bass drum with acoustic dampening material...
...There is already some deadening material in the kick drum. It doesn't sound too dead but it sounds a bit boomy. well see what we can do to make the kit sound better...
I'm sure he's familiar with the technique, as most of us here are. But to call it a cure-all for sucky sounds is ludicrous. When Bob Katz or any Mo-town engineer used Parallel compression, they weren't doing it to "cure a sucky sound".....probably because they made sure they didn't record sucky sounding drums to begin with. Maybe that's a part of the process YOU should do some research on.Yeah, that's exactly what I said: "parallel compression is the cure to all sucky sounds". The truth is, if you read up on Mixing, you'll find that parallel compression is very commonly used to beef up acoustic drum sounds. It's also used frequently in Mastering. Try reading Bob Katz's book, Mastering Audio, if you don't believe me.
In summary, you should probably do a little more research (or may even try it) before knocking what many consider to be a very useful technique.
To call any technique a cure-all for shittilly tracked instruments shows a complete lack of understanding of the whole recording process, no matter who's book you read.![]()
OK, I missed the earlier posts you were refering to. I just read this from you:That's my point--nowhere did I call it a "cure all for sucky sounds". There were plenty of other posters who had gone over all the basics, such as tuning, mic placement, etc. I was trying to say that using this technique can help. Sheesh, where do you guys come up with this stuff? I was just trying to help a guy get better-sounding drums in his mix! I didn't know there were so many parallel compression haters around here!
and didn't realize you were being sarcastic.Yeah, that's exactly what I said: "parallel compression is the cure to all sucky sounds".
OK, I missed the earlier posts you were refering to. I just read this from you: and didn't realize you were being sarcastic.
drums are recorded in a large room with high ceilings, the floors are wood but the drums are on a carpet. I don't have any samples I can post up right now but i could do that next week.What is the room like where the drums are being recorded? Tiled floor, all carpet, wood floor, low ceiling, high ceiling, small room , med room, large room....etc. Can you post a sample of the drum track?
Don't use the gels on the drums if they are tuned correctly, it will take away from the tone of the drums.
Oh man. There are many reasons why a drummer might not sound good in the studio, and some of the reasons might have little to do with him...
Mixerman, what a strange thread to come back to the HR.com in!
As for the OP, post samples!
What kind of crash cymbals is the drummer using? Those sound like pretty heavy cymbals to me. I generally prefer thinner crash cymbals in the studio: Thin, Medium-Thin, and nothing heavier than a Medium weight. If he's using Rock crashes, it may be tough to get a good sound out of them in the studio.
BTW, the hi-hat, ride, and drums sound pretty good to me for this to be a raw, unprocessed drum mix.
The cymbals are sabain, the ride, hi hats, and crashes are sabain b8's. The crashes are thin. We found with the recorder-man technique the drums sound way better. also the drummer spent an hour tuning his drums before we recorded. The only problem is the cymbals sound a bit loud in the mix.
