M
Mercuri
Ok, it's been a year since I've posted anything on this board... My last discussion was about getting "that" sound and how pissed off I was that it seemed so unachievable. One year later, I moved to Tennessee and I've gone to a couple studios in Nashville and checked the scene out. I've made a few discoveries I wouldn't have thought of before that I thought I'd relay to everyone who is trying to do this at home.
You know that "crispy" sound used in pop music, e.g. Justin Timberlake, Britney Spears, etc? The one that makes the sound "shimmer" and sound bright but not ear-piercing? That isn't some guy on the mixing board skillfully tuning the high EQ... That's HARMONICS. Check it out, people, cause it's what you need to get things to sound FULL even if you have a sparse mix. (Listen to N'Sync's "Gone" for a perfect example.)
Reverbs are used to add flavor, not wash out a sound. Don't always drown your sounds in echo to make them sound better... A touch of extremely short reverb and a gentle hall reverb will get things to sound "acceptable" without making the apparent sound obvious reverb does. I don't hear huge reverbs on a lot of things except Whitney Houston's voice, but that one is tastefully done and isn't a standard hall reverb just strapped over the channel.
EQ CONSERVATIVELY - If you have to make a drastic change in EQ, it better be to achieve a drastic sound, not to try to get something drastic to sound normal. Re-record it if the EQ doesn't sound good. Slight adjustments are more than acceptable.
COMPRESS THE S#!& OUT OF EVERYTHING. Don't make it sound compressed. Just level. Ok, maybe not everything. But do it if you want something to sound "in your face" and up front.
CHORUS SOUNDS CHEESY unless you make it not sound like chorus. I know that sounds weird. But try to stray from your standard Yamaha chorus. Listen to most chorusing on pro recordings. It doesn't sound like what comes out of your yamaha Motif.
CARVE FREQUENCY NICHES - Try to keep the kick out of the bass guitar's way, and don't let guitars take up too much of your lead vocal's frequency range (Unless they're for lead.) It's like a puzzle. The pieces have to fit.
DRUMS ARE HARD to get to sound the way they do on the radio. I have not achieved this yet and I think they're the hardest thing to capture correctly in recording and mixing.
Ok, I'm no great pro, and this advice won't apply to everything... But I thought I'd share some of my homework answers with the other students. All of this is also just my opinion and is stated factually nowhere... Take it as is. I hope this helps those out who are seeking to get a better sound out of their recordings. Ciao!
