fluxburn
I have this question on levels for music. Its obvious that when you make a mix everything cannot be LOUD. I guess you can try to make everything in the mix equal loudnesses then nothing would be loud correct? So the perception of one thing being loud in the mix is because others are softer?
I make dance music, I notice everyone has loud drums.... well at least the bass. Normally the HH and such are cleary distinct... at least. My question is I have all these melodys throughout the song, its hard to place them in the mix. You have some stuff going then you add new material and you are limited in db range... so it can only be so much louder.
Do you guys recommend pumping everything through a compressor to keep the mix tight... ie db levels super close?
Or should I keep some distance available in the db range to have a more dramatic effect?
Also do you normally mix levels first at like about negative a few db then bring up the whole mix to negative .1 db or do you try to run the levels to the max from the begining?
I have tried both, is one more proper then another persay?
I guess mixing is creative so all these questions are truely subjective... so what is your take.
