B
Bigus Dickus
I'm having a hard time figuring out what to do with this. What have you guys found to work well?
Reverb - what size room, predelay, etc. has worked for you? What about layering reverb? Delay?
Compression - do you compress the whole track? Limit? Do you attempt to compress the hammer attack differently than the sustain portion? If so, how can you do that?
Pan wide left and right? More centered (classical music here)?
Do you duplicate tracks and use different effects on those tracks? For example, larger reverb on wider panned tracks with the gain pulled back, and smaller room reverb on a more prominent track kept nearer the center? Etc.
Experimenting is certainly helpful, but there are a staggering number of possibilities. What advice can you give someone that has zero previous mixing experience? Knowing what direction to head in could be a tremendous help to me.
I've listened to lots of recordings for reference, but they're all different enough (in piano sound mostly) that it's hard for me to get a lot of direction from that.
