X man Da Legend said:
i have samples that are untreated as well it doesn't really take away from my question. I also use compression to control the dynamics of my drums i don't understand why it would make my drums sound bad I use compression now and I don't feel my drums sound bad they just don't sound exactly how I want them to.
You're missing my point.
You talked about pulling drum samples off LP's. Then stated you liked the sounds of the drums from Christina and N'Sync, etc...
I assumed you were sampling those drums, trying to replicate the sound(My bad for assuming). If that were the case, you'd be sampling a drum that's been compressed, EQ'd, and had reverb thrown on it... Then you're essentially adding more compression, EQ, and reverb in your own mix, making the drums overcompressed, and extremely muddy.
Listening to your mix on myspace, I can't tell a whole lot as to what your real issue is. It just sounds like an overcompressed, flat sample, in a decently mixed song.
Your best avenue to great drums, is using high quality (that doesn't always equate to high dollar), untreated samples. That gives you the freedom to add compression, EQ, reverb, etc... without destroying the quality of the sample.
And I assume the advice from the other forum is also correct. You're not utilizing the EQ as you should. Roll off your kick under 30hz, eliminate the boominess, brighten the snap of the kick in the midrange frequencies, and fatten it around 100hz-200hz. Muddyness can be EQ'd out around 250hz to 400hz, especially on something you've sampled from an existing song.
Get familiar with EQ. EQ is your friend. Glen has a great Frequency chart you can use to help get you familiar with what you're EQing and why.
