regebro said:
Why do you want to bus them as channel 8?
Shen you send it to a subgrop then you already have a volume control there.
If you absolutely want to do that, you take the sub out and patch it into the channel 8 in.
channel 8 on my mixer is patched into channel 8 on my otari. because otari uses the pin-3-hot-type xlr cables, I've had to run the i/o of the otari into a patchbay, which is normalled so that the first 8 channels of the mixer goes directly to the otari. the last 8 channels on the mixer are patched for playback only.
this is the first time I've actually used a physcial (read: non-DAW!) mixing board so I'm still trying to figure out the basics.
what I would do in pro (s)tools is assign the outputs of the drum tracks to a bus, say bus 1. then I would I assign the input of a channel fader, say channel 8, to bus 1. its very simple and intuitive, but I want to know how to do these things in the real world on a real mixing console!
so I have to actually patch a cable from the direct out of the subgroup to the input of the channel I want to go to? there's so way to send signal from one channel to another? it seems strange to have a mixing board with so many routing options, yet I still have to patch one channel to another.
I bought my console used and it didn't come with a manual. however, I just downloaded a .pdf, I'll start reading it! I have an old manual for a mackie 1604 that I've been referring to for basic stuff. I also have the yamaha sound reinforcement handbook and modern recording techniques, but there's not much there as far as basing mixing walk-throughs.
thanks everyone for you response.
