D
dmbfan1981
I am runing a Behringer mixer to a emu 0404 soundcard. I have two questions.
1- which outputs should i run to the card. the mixer has control room out, ALT 3-4 out and balanced XLR main outs. In addition it has the L-R AUX sends.
2- I am going to run back to the tape input for monitoring. (assuming this is the best way not to re-record the monitored signal.) The E-MU has 1/4 outputs. The mixer has RCA inputs on the tape. Should i use 1/4 cable and adapt one end to RCA? or use RCA cable and adapt one end to 1/4 inch.? does it matter?
ALSO if you know a better way to set this up other than this approach, feel free to let me know. I am fairly new to all of this. I just switched from a tascam us-122 because i felt that it was very limited.
