C
Cheeky Monkey
Hi. I'm entirely new to recording. I'm a guitarist and plan to record acoustic and electric guitars and all other instruments myself (bass guitar, drums and keys via a USB Midi Keyboard Controller) in a small bedroom studio. Based on research I've been doing here at HR.com over the past few months, I've been purchasing components, and I now have (or will have within a couple of weeks) enough gear to get started. But first, I have to get everything properly connected. I've been reading the manuals that came with the gear -- an Audiophile 2496 soundcard, a pair of Wharefdale Diamond Pro 8.2a monitors and a Wharfedale R1604 mixer -- but I can't figure out how to connect everything. The manuals aren't very clear about that. I've even tried to research connectivity here, but I haven't found much useful info and I'm still confused.
The following is my understanding (please correct me where I'm wrong) along with a number of questions...
- The MXL V67G (for vocals) and pair of MXL 603s (to x/y my acoustic) (now on order) will connect to three of the XLR channels on the mixer. My electric guitar 1/4" cable will connect to my Line6 POD then to the Line Input on the fourth channel. Then, I believe I have to connect the unbalanced 1/4" Aux 1 and 2 Sends directly to the RCA Analog Ins 1 & 2 of the Audiophile. If so, does Aux Send 1 go to In 1 (left) and Aux Send 2 to the In 2 (right). If this is so, does it really matter which Audiophile Ins the Aux Sends from the mixer connect to? As for the correct cable to buy, should I get a 1/4" (one end)/RCA (other end) (assuming cables are made like this), or a 1/4"-1/4" and attach an RCA adapter on the end to go into the Audiophile? Is one arrangement better than the other? I speculate it doesn't matter.
- The Audiophile manual mentions the various Windows requirements, but doesn't mention XP. Will my card work with XP once I install it? Also, although the included CD has the drivers, I assume I should download the latest? The manual says that there's a Digital Monitor Mixer. Since I have Cubase SX 2.0, do I need to use this Digital Monitor Mixer in Audiophile?
- Where do the Audiophile Analog Outs 1 & 2 go? To the mixer, or directly to the monitors? I suspect to the mixer, but if so, what jacks do they connect to? The only inputs available seem to be:
* Stereo EFX Returns (accepts 1/4"),
* 2-Track In/Out (accepts RCA), and
* Control Room Out (accepts 1/4"). I suspect this CR Out might be used to connect directly to the monitors (XLR). If not, maybe it's the Main Outs on the back of the mixer that connects to the monitors?
- The back of the mixer has a Main Output section (a right and left balanced XLR out, and a right and left balanced 1/4" out), and an Alt Output section (a right and left balanced 1/4" out). As I said above, is it possible that the Main Out XLRs go to the monitors? If not, where do they go to? As for the Alt Output section, I have no idea what this is for.
- I'm also about to buy a small (49 key) M-Audio USB Midi Keyboard Controller. I assume this will just connect to the USB of the PC and not need the Midi In/Out on the Audiophile breakout cable connector? Also, with such a keyboard, are there any cables that'll go from the keyboard to the mixer? If so, where would they connect?
- Based on my gear/setup, I assume I won't be using the S/PDIF (whatever that stands for???) on the Audiophile breakout cable connector???
I realize I've asked a LOT of questions. Thanks in advance for any help. Much appreciated!
