D
dbsoccer
Member
I have a Mackie Mix5 mixer and need some help with understanding and settings - starting with the mic gain. I am using a Shure 58 microphone.
Mackie has a set-up video on setting the gain but it is not clear how the gain works with the line level setting for the Channel 1. Per the video, the mic gain is set with the Channel 1 and Main Output Line Levels set at the unity mark. Then the mic gain knob is adjusted so the main output meter bounces around zero with mic input (speaking singing, etc.) equal to that of a performance. But then the person demonstrating zeros mic line level and moves on with some other adjustments.
So with the mic line level at zero and using a performance level input to the mic, the main output meter does not register anything. So what is the purpose of setting the mic gain? Is it like 'tuning' the mic the mixer for lack of a better way to describe it?
At some point the line level of Channel 1 and the other channels will need to be increased and balanced while not clipping the main output, but that's a future question......
