Hello folks...
I really need clarification on something, so I hope you all can help.
Besides doing home recording, I play 3-4 gigs a year with a pop/rock band, and with a bluegrass band. For the past two years, I've been using a Mackie 1202 VLZ Pro mixer for home recording (using the four insert outs into my Akai DPS16). In addition, I've taped some live gigs, again using the inserts as direct feeds into the Akai (for four channels, anyway).
Today, I ordered the Yamaha MG 16/4...I've read very good things about it here. The reason for the new mixer is that I was tired of working around the limitation of having only four insert outs on the Mackie...
My concern...in the manual (which I downloaded from MusiciansFriend.com), it states the following:
"The signal output from the Insert I/O jack is reverse-phased. This will not be a problem if connecting the jack to an effecter. if using the jack to output to an external device, however, please be aware of possible phase conflicts with other signals."
So, here are my questions....
If I'm recording my band at home, on 8 simultaneous tracks, and I'm employing the "one-click" method with the cables...will I get a nice, clean sound on each track? Will it be pre-fader? (someone wrote on another thread that the Yamahas are different in this respect).
Another question...if I'm recording a live gig, and using the same method as above, where will the phase problems occur? Let's keep it simple for now and say that I'm only using 8 tracks for both the recording and the live mix (bass, 2 guitars, three vocal mics, two drum mics).
Everything always worked fine with the Mackie, but this "reverse-phase" thing has got me rattled! I know that this has come up before (someone else even posted the same quote from the Yamaha manual), but if I could get a detailed, yet simple, answer, I would be very grateful. Sorry for the length of the post!!!
- Bob.
- Bob.
