One could use the Behringer as a submixer, sending the main L/R output to the Duet's 1/4" inputs.
Pro's: Ability to use as many inputs as the Behringer has.
Con's: Inability to edit the individual signals once they are submixed. You also can't use both of the Apogee's mic preamps and 1/4" inputs simultaneously. You
could use one preamp and one 1/4" for a mono submix at the same time, but you have to pick two inputs (vs. four).
This makes sense to me as I'm writing it, but it may not translate well.
I could see doing this for something like drums. Perhaps you come up with a mix of drum mic's you're happy with, and just record the stereo mix of drums. Same for ensemble work... say, four mic's on a string quartet tracked in stereo.
More importantly, however, is the quality of preamp. No offense to Behringer gear, but it's not in the same class as Apogee. Using a small Behri mixer in front of the Duet is like having a Mercedes and putting K-Mart tires on it. If you truly need more simultaneous inputs and want to preserve the audio quality you're getting now, you might look at upgrading to
the Apogee Ensemble.
